Help can't print boarding tickets for flight tomorrow!!!
8 Jun 2006
Hertfordshire
Guys
For some reason when I print web pages it seems to miss most things out??
If I do a print preview the screen is blank??
Desperately need to print tickets for family holiday tomorrow?
Any advice would be great!!
tbh its a solution :P just do it, the flight is tomorrow!
P.S. maybe next time you'll do it earlier? :P
have you tried printers > properties > print preferences > page setup> and then there should be some sort of print scaling or print to fit option (which varies from printer to printer) under the page layout tab. then print one page at a time if need be
Guys
try reinstalling the printer with newer drivers.
You don't actually need to print out the tickets, you can just take the reference number to the check-in desk and they'll print them for you...
Did re install, tried it on my pc and the wifes laptop and still the same?
Printer has been fine and printer out other stuff normally?
And yes we should have done it ealry but lifes hectic with 2 kids as always!
Thanks guys
What website are you trying to print from? I'd have expected them to have a Print button on the page itself that changes the stylesheet, if you're required to print them yourself.
Have you tried 'select all' on the web page (highlight everything) and then in printer properties select 'print selection'?
Internet cafe perhaps??
They will charge you about 50p a page, and airport checkin might charge you £4 or so. (If it's a budget airline they will try and squeeze as much pennies out of yuo with all the little things).
Tbh, I wouldn't want to stress out about trying to fic my computer just before a trip;
