Help! Case fans not working.
18 Sep 2017
I have a Phanteks Eclipse P400 Midi case and a Gigabyte AB350M-Gaming 3 motherboard.
I have an issue where the stock case fans aren't working.
Rest of the PC and components work fine - currently installing windows!
I do have two spare unconnected case cables, which I think might be the ticket. But they use small, brown, block-ish 3 hole connectors.
However, the two SYS FAN connectors on the motherboard are 4 pin.
I can't find where else to plug them in so am a bit stuck.
I've attached a screenshot showing me holding the 3 hole connector with the 4 pin SYS fan socket on the motherboard just above my hand, to the right of the chunky plugged in USB 3.0 cable.
Screenshot here: https://~ibb.co~/dZVQEm
Can anyone point me in the right direction?
Many thanks in advance!
do 3 pin case fan cables work in 4 pin motherboard connectors?
Yes.
Look at a 4pin connector and the plastic tab is placed across just 3 of the 4pins so you know where to put a 3pin fan.
