Help Changing a Fluorescent Tube on an Old Fitzgerald Light Fitting
24 Sep 2007
Hi Guys
The fluorescent light in my kitchen is flickering badly and needs attention. The house was built in the late 80s and so it's an old light fitting made by Fitzgerald. Below are pics.
I've heard that sometimes you just need to replace the starter, the circular thing to the right of the Fitzgerald label. However, I can't move this, it won't turn or push in. Any ideas?
Otherwise I could try replacing the tube. Anyone know the correct technique for removing this on this older light fitting? It's not like the more recent ones where you twist and remove. I've tried pushing the tube into the fitting to remove, but there's not enough give and I don't want to break it. Does anyone know the correct technique?
Thanks
Remove the end caps that hold the defuser on, you should then be able to swing the connector pieces out far enough to remove the tube.
Personally, I'd replace it entirely with an LED replacement.
Change the tube. That picture with the black end suggests that the tube is well past its sell by date!
The starters should be removable by rotating anti-clockwise, Like a BC light bulb.
Other than that, this being the time for an upgrade is not a bad suggestion.
:p
To remove this you need to twist counter clockwise, only a little and then it should come out. They can be very stiff.
Just out of interest, does anyone know if they still make the replacement tubes for this type of old fitting? The current tube is an Osram L40W/23 UK.
Thanks
Thanks
You can still get them, what you are looking for is a T12 2ft (600 mm) tube. 20-40 W.
https://www.amazon.co.uk/T12-Fluore...t12+tube+2ft&qid=1556055560&s=gateway&sr=8-11
https://www.bltdirect.com/fluorescent-t12-20-watt-600mm-2ft-warm-white
https://www.ebay.co.uk/itm/5-x-Osra...uorescent-Tube-3500k-White-RARE-/322002891894
There are retro fit led bulbs, but most 2ft versions are T8 not T12 which I think it what you have. T12 = 38mm diameter. Measure yours to make sure.
