I've been looking at water cooling my case because of its size it get really hot (super lanboy) and the DFI chipset fan on my lan party is compleatly covered by my 8800 GTS so there is no airflow, and it doesnt help that the 8800 runs hot too.
http://img457.imageshack.us/img457/1246/1000908ic0.jpg
The chipset is the main problem. At idle the chipset is 55 and the CPU 35 but when gaming can go upto 75 and 50. I was looking at this swiftech bundle and then getting my self a waterblock for the chipset and possibly in the future one for the GPU.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-014-SW
But all the chipset coolers look as if they wont fit because of the graphics card. All the piping goes in onto the block rather than off the top of it. I was wondering if any of you could help, will the card still fit with these blocks as most newer cards cover the chipset now anyway??
Thanks
Thanks
