Hi guys, first post here
i have a system with the following
i7 920 2.66
xfx gtx 285 (used to have a 4870x2 but malfuctioned and got the 285 as replacement + some other stuff)
P6T deluxe
corsair 6gb
case origen 21T
Everything was fine till recently. i was playing the latest call of duty with no issues but 3weeks ago decided to buy the bf3. Then i was not able to play the game on full specs 1920x1200 with high i got shakes in the process and i had to put low. Even in medium specs i got some flickering etc
Now at low the game gets stuck after 2-3hours i believe the card is getting hot but the nvidia control panel doesnt have anything that allows me to control the card fan like ati had
Anyways, i'm off for a meeting in the US next week and i'm thinking of buying a new card.
i need to have 3-4 outputs as the pc is hooked to the tv, projector, monitor and the case touch screen. Should i buy something like the 7970 or is it too much? I'm not considered with any benchmarks just to be able to play the game at full with no issues
would a 6990/6970 do the work? should i get a 7970 since i will be in the US
Also any issue with the size? Given i had a 4870x2 it should be ok right? My case is quite big but the structure is strange is its a htpc case
thanks for the help
i7 920 2.66
P6T deluxe
corsair 6gb
case origen 21T
thanks for the help
