Help choose router
27 Nov 2009
Hello Dear overclockers uk forum
I'm currently using VirginMedia supehub.
I've had lots of problems with it or with internet, anyway to check my problems need choose better router with all types of WiFi connections bgn with good software and ability to be stable all time.
Market is flooded with choose of routers and it's routine for me to find out which is good and which is bad.
for gaming, torrents and other everyday thinks needs.
Best router after years of practice please. without theory
Thanks,
Andrey
i have exactly the same problem and just ordered the asus (arriving tommorow).
asus is meant to be the best especially at the price.
Price true, but had negative practice with Asus in 2006-7-8. Had two similar routers, one home other in office.
at home router dropped connections wifi and cables after 1 month.
at office dropped after one year and was not possible to stop these problems.
After all practices found out lots of customers had same problems with these models, even update into linux base didn't helped.
That why I didn't looked routers for these years until today, coz spends doesn't affect on quality, but could be today new routers can be stable (newest levels of microelectronics)
Avathar77
KIA
Thanks for reply n have fun.
Can you recommend me a router with a good coverage but not too expensive? Something in the sub 40 pound range? I do nto need any extras really, just good coverage (singla spreads out well through floors and walls) and quick
The TP-Link hardware is the budget end reliable (ish) kit. Avoid Netgear link the plague.
