- 10 Aug 2012
Just popping in for some suggestions for a budget case.
Just got all my new stuff from OC but the new heat sink is a bit big for my current case.
I'm not looking to spend much over £100 and every penny below that would be a bonus. Other than that the only restriction are it needs to be able to fit a Corsair A50 width wise and a Radeon 5800 length wise so that's about 20cm wide with a 24-27cm card length wise. Height isn't a huge issue as long as I can fit two SATA drives (room for expansion would be a plus if I decide to go for a SSD at some point), DVD. Front USBs and headphone/mic inpute would be a good but not expressly required.
