- 23 Jun 2014
- Cornwall
Hello all, I'm a forum newbie so this is my first post
Firstly all the detailed specs of my PC:
Acer Aspire T180 case
Thermaltake toughpower 650W PSU with a replacement Noctua NF-P14s Redux 1500 PWM fan (modified to 2 pin connector)
ASRock K10N78FullHD-hSLI R3.0 MOBO
4 x 1GB Crucial Ballistix DDR2800 PC6400 running at 2V 4-4-4-12
Nvidia GeForce 9400GT 512MB
Thermaltake ISGC 100 Heatsink/Cooler
1 x 256GB Crucial MX550 SSD
1 x 500GB Western Digital Green
1 x 500GB Seagate Pipeline HD2
1 x 160GB Western Digital WD1600JS
LG Super Multi DVD GSA4082B
Smart Media Multi Card reader
Belkin F5D5005 V2000 Gigabit PCI Card
I've just picked up a Phenom II X6 1090T CPU with a stock cooler and am thinking about a BD/CD/DVD RW/ROM drive for it too. I was also considering taking the RAM up to the max 16GB DDR2 1066 the MOBO supports. I'm also going over from XP Home to Win 7 Pro 64. A new GPU will no doubt follow too. I'm not looking to overclock it but I am intending to add some music recording gear to it by way of interface, DAW etc in the very near future.
Oh and I also have a Targa Visionary LCD 17-3 monitor which I will be looking to replace with a 1080P widescreen of a decent size.
So, a few questions I need some help with...
The RAM, when I go to crucial and look up the board or do a system scan it reports back that my board only accepts 8GB of 6400 yet ASRock clearly states otherwise. Why is this? Where can I get the DDR2 1066 and what should I go for brand and model wise?
The heatsink/cooler, the TT ISGC 100 does OK for the AMD Athlon 64 X2 4200+ in there at the minute but I don't think it will handle the Phenom X6 and I don't want to use the stock cooler as I am sure it won't be any better than the TT would be. I've been looking at replacements and have came up with Noctua NH-D14 Dual and the Cooler Master Hyper 212 Evo. However, I believe my case is too small for either to fit. The Noctua website says my MOBO and RAM setup will take the NH-D14 and it will clear the Ballistix RAM no problem. The Coolermaster I can't find any compatibility info. There isn't much room in my case and it only has one rear mount exhaust fan and no option to fit more inlet or exhaust fans so I'd have to start hacking the case to fit more and would need a fan controller as it only has one fan header on the mobo. The PSU doesn't help as it is not modular so there's a shedload of cable bundle in there.
What would be the advice here? New case (obviously one which can fit my MOBO). A different replacement heatsink/cooler? If so which?
I really like the NZXT Phantom cases but will my MOBO go in one?
I also considered whether to go for a new MOBO and CPU as well but budget may not allow it as I would likely want to go all out on and Intel i7 which look rather expensive so I figure going this route will get me running the best I can for some time until I get the money together to make the jump.
Thanks for any and all advice and I look forward to reading your suggestions and options!
Cheers,
Mick
Cheers,
Mick
or am I just confusing myself here? e.g. "Big Tower" used by OCUK, is this the same as "Full Tower" or is it "Ultra Tower" or "Ultra + Tower" used by NZXT). The red window side panel bought separate and Enthusiast Full Tower is out of stock too.
