- 4 Nov 2002
- England - Leeds
Hi there people, was just looking for some advice and also if you could answer some questions.
I've been looking at getting one from halfords as theres a store near me and I like the look of some of their bikes.
I've narrowed it down to these 6 which I think are good brands and have good reviews:
http://www.halfords.com/webapp/wcs/..._productId_786839_langId_-1_categoryId_165499
http://www.halfords.com/webapp/wcs/...uctId_927853_langId_-1_categoryId_165499#tab1
http://www.halfords.com/webapp/wcs/...uctId_777775_langId_-1_categoryId_165499#tab2
http://www.halfords.com/webapp/wcs/...uctId_810671_langId_-1_categoryId_165499#tab1
http://www.halfords.com/webapp/wcs/...uctId_810659_langId_-1_categoryId_165499#tab2
http://www.halfords.com/webapp/wcs/...uctId_810749_langId_-1_categoryId_165499#tab2
I dont know anything about bikes and so its hard for me to tell the differance between them and not sure how good the specs are but they look good to me and I like the sound of hydraulic disc brakes lol.
Do you think suspension is good if your weighing 19st? I've seen people say dont get it for riding on the road but you can tighten it up cant you? and also my last bike the back wheel kept breaking because the bar inside the wheel, not sure how to explain it, but you know the bar that goes through the back wheel that all your weight pushes down on? and theres loads of little ball bearings inside. Well that broke and then I bought another wheel and then after a month it did the same thing again. So not sure how to avoid this problem in the future if I can buy a stronger wheel or something?
Thanks in advance.
Thanks in advance.
no need for suspension, and seriously a 19stone guy on a mtb with cheap suspension parts?! not cool IMO
