I'm having trouble deciding on a system from all the specs people have given me. I was originally going to go for the AMD 940 but since realising it's only AM2+ I've been looking at the AMD 955. I then noticed the AMD 720 which has really good reviews for gaming and is a ton cheaper than the 955. Set on this, I then realised I could get an i7 (didn't think I could afford one originally).
Here are the four specs I'm working with. The prices/components are pretty rough at the min. I want to decide on a definate processor before I iron out an exact spec.
As you can see the better the processor the worse the graphics card etc. This is already pushing my budget to the max.
The system will be used for roughly:
20% High end gaming (Crysis etc)
40% Other gaming (Older less demanding games)
20% Photoshop
10% Webdesign (Dreamweaver)
10% General web browsing, file creation etc.
Resolution is 1920x1200 on dual 24" monitors and i like to run games on max setting with as much AA as possible
I will also be doing some moderate overclocking.
OK - PLACE YOUR VOTES NOW!
20% Photoshop
