Hi Ladies & Gents,
I have spec'd two pc's but can not decide between them i was wondering if you could help me decide.
Use for them is Gaming / 3D Rendering using a program called Fusion 2020 a kitchen / bedroom design program.
any help would be greatly appreciated.
Spec 1.
3XS Z170 Cyclone
LN66562 * 3XS ONLY * Intel Core i7 6700K CPU
LN64660 *3XS LOGO* 16GB Kingston USB3 Pendrive for Windows Recovery Media
LN63498 120GB Corsair Force LS v2 Series, 2.5" SSD, SATA III 6Gb/s, MLC NAND Flash, Read 540MB/s, Write 450MB/s, 43k/23k IOPS
LN64276 128GB Samsung SM951, M.2 (22x80) PCIe 3.0 (x4) NVMe SSD, MLC NAND, Read 2000MB/s, Write 650MB/s, 300k/83k IOPS
LN63318 12GB EVGA GTX TITAN X SC GAMING, PCIe 3.0, 7010MHz GDDR5, GPU 1127MHz, Boost 1216MHz, Cores 3072, 3x DP1.2/HDMI/DVI-I DL
LN44585 140mm Corsair Air Series AF140 Quiet Edition, High Airflow & Low Noise, 1150rpm, 67.8CFM, 24dB, 3-Pin, Single Pack
LN58929 2 x 1L Mayhems Pastel Blue Berry Coolant
LN42857 2TB Seagate ST2000DM001 Barracuda 7200.14 SATA 3 6GB/s 7200rpm 64MB Cache 8ms OEM NCQ
LN46437 3 Year Warranty - 1st Year Onsite, 2nd & 3rd Year Return to Base (Parts & Labour)
LN32790 3 x 30cm Akasa AK-CBPW02-30 Molex (4pin) Cable extension - 4pin male to female connectors
LN66398 32GB (2x16GB) Corsair DDR4 Vengeance LPX Black, PC4-21300 (2666), Non-ECC Unbuffered, CAS 16-18-18-35, XMP 2.0, 1.2V
LN44803 360mm Alphacool NexXxoS ST30 Full Copper 360
LN66404 3M EK PrimoChill PrimoFlex™ Advanced LRT™ 19,1 / 12,7 mm, Crystal Clear Tube
LN33698 3XS Cyclone SLI - Custom Series
LN48272 3XS Estimated Build - 5 Working Days
LN45114 3XS Extreme Overclock - Check Build Sheet
LN56155 3XS GPU Overclock
LN61212 3 x 3XS Only Corsair SP120 PWM Quiet Single Fan (Red/Blue/White Ring)
LN61909 7 x 3XS System Build
LN57605 3XS Upgrade Premium
LN66314 3XS Windows 10 PRO G15-20001 GML LABEL
LN47806 760W Corsair AX760, Full Modular, 80 PLUS Platinum, 1x120mm Fan, ATX v2.31, PSU
LN40801 3 x Akasa PWM fan splitter Supports 2 PWM fans from a single motherboard PWM header
LN67100 Asus 3XS MAXIMUS VIII HERO Motherboard z170
LN53701 Corsair Obsidian 750D Black Full Tower case Aluminium Steel with Side Window 3x140mm Fans USB 3.0 E-ATX/ATX w/o PSU
LN43241 4 x EK-Extender G1/4 (EN) Both connectors male-female
LN63355 EK-FC Titan X High Performance Nickel Acetal Full Cover Water Block for Reference Design GTX TITAN X/980Ti Graphics Card
LN52759 2 x EK-HD Adapter 12/16mm - Black Nickel, Solid-tube Fitting
LN52766 EK-HD Tube 12/16mm 3-Slot (2 pcs)
LN50013 EK-RES X3 - TUBE 400 (Outer) - 354mm
LN59458 EK-Supremacy EVO - Full Nickel (Original CSQ)
LN67081 EKWB EK-XRES 100 Revo D5 PWM High Performance Cooling Pump + Integrated Reservoir, 4Pin Molex + 4Pin PWM Fan Connector
LN45864 2 x Monsoon 19/13mm (ID 1/2" OD 3/4") Compression Fitting Straight - Matte Black - 6 Pack
LN49552 Monsoon 19/13mm (OD 3/4") Rotary 90° - Matte Black
LN64750 Samsung SH-224FB/BEBE 24x Internal DVD Writer with MDISC Support, CD/DVD Read/Write, 5.25", SATA, Black, OEM
LN56560 Scan 3XS 5.25" brand & card reader Aluminum front Panel
LN45708 Scan 3XS System - 3 Year Warranty (Mainland UK) - 1st Year Onsite, 2nd & 3rd Year Return to Base (Parts & Labour)
LN51520 Silverstone SST-LS01A, LED Light Strip, Blue
LN55098 System
LN66206 Windows 10 Professional DPK FQC-08797
Spec 2.
3XS X99 Carbon Ti SLI
LN37092 100cm NZXT CB-LED10-GR GREEN Sleeved LED Kit with PCI Light Sensivity Card
LN61674 250GB Samsung 850 EVO, 2.5" SSD, SATA III 6Gb/s, MGX, 3D V-NAND, 512MB Cache, Read 540MB/s, Write 520MB/s, 97k IOPS
LN45454 3XS Carbon SLI - Custom Series
LN66039 3XS Only RM750W RMi Modular Gold Silent PSU
LN61909 3 x 3XS System Build
LN61156 64GB (8x8GB) Corsair DDR4 Vengeance LPX Black, PC4-19200 (2400), Non-ECC Unbuffered, CAS 14-16-16-31, XMP 2.0, 1.2V
LN63161 Asus ROG RAMPAGE V EXTREME/USB3.1 GAMING MB, Intel X99, S 2011-3, DDR4, SATA III 6Gb/s, PCIe 3.0, 2x SATA Express, E-ATX
LN65696 Corsair Hydro Series H110i GTX High Performance CPU Cooler with 280mm Radiator, 1150/1/5/6/1366/2011/-3 + FM1/2/AM2/3
LN58536 Intel Core i7 5930K Unlocked, S 2011-3, Haswell-E, 6 Core, 3.5GHz Clock, 3.7GHz Turbo, 15MB, 40 Lane, 140W,+3 FREE Games
LN56694 LG UH12NS30 Internal Blu-ray ROM DVD Writer SATA, 12x BD-R, 16x DVD±R Write OEM
LN55098 System
LN62020 Thermaltake Core X9 Stackable Black E-ATX Case with Side Window + 4x USB 3.0 w/o PSU
Thank you so much for any advise you can give me on this.
Ben
Spec 1.
3XS Z170 Cyclone
LN55098 System
Spec 2.
LN55098 System
Ben
