Hi all.
Due to losing my man cave to my unborn child (better be greatful!) I've now been relegated to downstairs.
I cant really have my full set up anymore so i'm looking into the mad, overly garish world of "gaming laptops".
Through my research so far every laptop ive looked at has a fatal flaw. Be it the screen, temps, keyboard or build quality.
My budget is £2500 MAX. Ideally i'd like....
1.6700HQ or preferably 6820HQ
2.GTX 1070 or 1080
3.G-SYNC
4.16gb ram
5.256gb M.2 or SDD
6.1TD backup drive (7200rpm preferred)
7.Decent keyboard (i'm no novel writer, just dont want an inferior keyboard)
8.Isnt 2-3c off its thresh hold temp when being pushed hard, noise isnt a huge concern but i'd like to have some ear drums left.
And lastly its the screen which i've struggled with the most. If its 4k then i'll want a 1080 but if its a 1070 ill settle with 1080p. Both need to have G-Sync but panel quality takes priority. Ill consider both 15 inch or 17inch.
I wouldnt mind 1440p but the only laptops with something like that i've seen is the Aorus but i read of noise and temp issues.
A competitor makes their own laptops and for bang on £2500 i can get a 4k screen, 1080, 256gb m.2 etc that meets my max budget but heard middling things on build quality in general and the screen quality.
HELP ME!!!
2.GTX 1070 or 1080
3.G-SYNC
4.16gb ram
5.256gb M.2 or SDD
HELP ME!!!
