Help choosing m/board please
23 Jan 2006
Hello,
I'm looking to spec a full new system, so i thought i should start with the motherboard.
You all seem very knowledgable so i thought i'd ask for some assistance
My requirements:
I would prefer to use an Athlon-compatible board over Intel.
The motherboard needs to be the most future-proofed part of the system so something with everything i will need for a while.
I would feel silly paying more than £100 for a board, unless theres a particular reason that makes it worthwhile.
The system will be used for gaming mostly, along with online/basic office work
I have no interest in overclocking/modifying from stock
please, spec away!
If you are not overclocking then get the cheapest board that you can find with the features you need.
I you need firewire multiple USB ports etc...
But as you are not buying straightaway it seems you might as well wait for socket AM2 to arrive an go from there.
