- 3 Dec 2011
Hi there!
I was just wondering if any of you guys could help us on the memory front of my new system I'm building. I've currently ordered the 2700k and the maximus extreme-z. I'm not too sure what sort of thing to go for whether its Cas or MHz, and if the speed makes that much of a difference over the amount of memory installed.
I've seen a few kits including 16gb but at 1600mhz for instance but then there's kits that run at 2000mhz+ but with less memory for the same price like only 8gb etc. so what suggestions do you think I should go for?
