Help choosing next PC
26 Nov 2006
Hi ppl, ok my old computer specs are like P4 2.66Ghz, ATI X800, 2 gig ram etc - as you can tell its well ancient - its ok to play bf2/bf2142/ut2k4 etc. I now am looking for a new PC and its been like hmmm 4 years plus since I upgraded my old PC.... Just wanted some adv really.... This is what I have selected so far:
Gainward ATI Radeon HD 4870 X2 "Golden Sample" 2048MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail Gainward ATI Radeon HD 4870 X2 "Golden Sample" 2048MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail £394.44
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail £249.54
Gigabyte EX58-UD4P Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard Gigabyte EX58-UD4P Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £213.89
Lian Li PC-A71A Aluminium Tower Case - Silver (No PSU) Lian Li PC-A71A Aluminium Tower Case - Silver (No PSU) £152.94
Akasa AK-P010FG-BK 1000W PowerMax Power Supply Akasa AK-P010FG-BK 1000W PowerMax Power Supply £126.98
OCZ Reaper 6GB (3 X 2GB) DDR3 PC3-14400 (1800MHz) Tri-Channel (OCZ3RPR1800LV6GK) OCZ Reaper 6GB (3 X 2GB) DDR3 PC3-14400 (1800MHz) Tri-Channel (OCZ3RPR1800LV6GK) £113.99
Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM (ST31500341AS) Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM (ST31500341AS) £110.39
Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional Series 7.1 Sound Card (70SB088600000) Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional Series 7.1 Sound Card (70SB088600000) £89.69
Sony NEC Optiarc DRU-860S 22x DVD±RW SATA Dual Layer ReWriter (Black/Silver) - Retail Sony NEC Optiarc DRU-860S 22x DVD±RW SATA Dual Layer ReWriter (Black/Silver) - Retail £25.29
What do you think? My budget is MAX £1500 but if the job can be done for less, even better....
Any pointers would be great - if you think the mob/cpu/gpu etc is the wrong choice, please adv what you think would be better suited for price and performance-
Cheers
I think that it looks good, and will definately be a massive upgrade for you, but I would recommend you look at a different PSU, Corsair, Be Quiet! or enermax will be a lot better than that akasa in terms of reliability. Personally I would get a Be Quiet myself, they cost more but will definately be worth the extra expense. Also you might want to consider a better CPU cooler than the stock one, the akasa nero is a good price for its performance.
Hawker
What size monitor you using? If its a 4 year old monitor too then theres a good chance the gfx card will be overkill, unless youre getting a new 24"+ monitor too?
Good point.
If you're playing 1900X1200 and above, then the 4870X2 is fine. Otherwise, it's overkill.
Good point.
I'm interested in this Overkill term, Im getting this card on my 17' Monitor which handles 1080x1024 which i guess is standard for a 17'.
What does it mean? im not using the real full power of the card, so i might aswell of got a lower priced one instead to run it at those resolutions?
I do need a new Monitor but i dont want a huge one, i was thinking maybe a 19' would do it?
i have a 4870 i gb and every game plays max settings in 1900x1200 except crysis which plays max in 1600*1200 so 4870x2 is well over kill. what you planning on doing witht the sytem?
Yeah basically, if you're not planning on going above 19" monitor then theres no point spending so much on a gfx card, the monitor will hold back the gfx card basically
If you have no plans to go bigger than this then a half gig 4870 will more than suffice, 4850 even
