hi guys, basically had a house party the other day and due to the effects of too much booze and forgetting to make sure the vents at the top of the amp were clear when playing loud music, my amp blew...
what happened is that things got too hot for the ampand first the treble went in the speakers and then the amp just shut itself of...
the speakers i have are:
http://www.celestion.com/products/fseries/f30.html
Power handling
120 Watts
Sensitivity (2.83V/1m)
90 db
Impedance
8 Ohm
The amplifier that i had was a cambridge audio a5:
Output Wattage (Wpc) 60 Maximum power output, RMS, per channel, into 8ohms.
Seemed to do the job. i was however wondering if anyone just had any other amps that would maybe be an improvement. Looking to spend £120-£150.
THanks guys
Power handling
120 Watts
90 db
Impedance
8 Ohm
THanks guys
