- 6 Jun 2010
Hi there im looking to buy a budget video card to retire my onboard graphics. Im NOT much of a gamer, but i do like my video editing and image rendering quite a lot. Also use the rig as a HTPC so HD support for viewing and editing is a must. Support for more than 1 monitor is also a must. Having done benchmark test on my graphics i found my score to be embarrassingly low. I want to buy a video card that will run with my current equipment, that is...
Asrock N68C-S Motherboard
AMD Phenom FX-5000 Quad-Core Processor at 3.0GHz (disregard the sig freq)
2GB OCZ Platinum Revision 2 PC2-6400 800MHz CL5
I dont want to spend too much, probably £100 maximum, ive had a quick look.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-177-XF&groupid=701&catid=56&subcat=708
How would this one work with my current stuff? i only choose that because its bang on my max....if theres a cheaper one with similar performance i would be inclided to pay less....Any suggestions would be great. Cheers
