Help - Cisco Switches
Ish
Ish
11 Jan 2006
West Midlands
Hi
We had a couple of Cisco 2950 switches donated to our charity organisation.
We just want to use them as basic unmanaged switches. How do I do this or is there some kind of simple manual for it I can download (by the looks of it Cisco don't do simple!)
Going down the simplistic/unmanaged route - Wipe the NVRAM, reboot them, run using default configuration (single VLAN etc).... start plugging devices in.
Hold down the Mode button on the front for around 30 seconds. All the lights will change, let go.
You now have a "dumb" switch.
