Help Clocking my 6400 on p5w dh please guys
21 Jan 2003
Northamptonshire
Hey up,
Right i have got a 6400
1 x asus p5w dh
and 4 x gskil 1gb 6400hz sticks of ram.
i can only seem to get it to post at 300mhz fsb, any more and she wont boot.
can anyone help me with bios settings and such.
cheers
Datamonkey said:
Hey up,
1 x asus p5w dh
cheers
wes, nice to see you finally jumped on the wagon :D
set your memory to 1:1
chipset to 1.6-1.65
i think default vcore should be fine for now till you get around 3Ghz+
set memory to 5,5,5,15 @ 2v (you can tighten them later)
use bios 903 or 901
4 x 1gb, what you doing with that :D
chipset to 1.6-1.65
use bios 903 or 901
I cant find bios 901 or 903, any chance of a link?
ok i have managed to get the following,
turns out hyper path is the culprit to no boot.
turned it off now running @ approx 3.4ghz lol
need to test for stability.
is 1.45v ok throught the core on these lol always was the maic number with my 3.2 p4
using a ninja with 120mm fan.
just doing an os install as i type
aint got time to bench,
i got games to install and test lol.
will do some benches later on. when the wow new factor has worn off a bit :D
i still want your quad core :D
