Greetings Overclockers
Im pretty dense with the specifics of what makes a good PC, so I have some general questions that I hope someone could help me with.
Im looking to replace my PC, my original thought was to spend quite a bit of money now-and get myself a badass machine that will last a good while. I mainly want a PC for gaming and a bit of light photoshop in the main.
I dont really run particularly demanding games (Command & Conquer 3 is probably the most demanding game I own) so in a sense it has not got to be all powerful, but then as mentioned, I want something that will last me a while.
A couple of specific questions-
1) What is all this talk of overclocking?
2) Should processor speeds concern me? If so what should I be aiming for?
3) Is a badass graphics card my main priority?
4) Why for example is the Intel Core 2 Quad pro cheaper than the Core 2 Duo? Isnt quad better than Duo?
5) Whats a good size hard drive, the standard seems to be 500GB- is that enough for average PC use?
6) For the sake of £18 you can upgrade to 4 GB of memory which seems a good deal but then you must have a 64bit O.S to take advantage of said memory- which presumably means Vista. I heard Vista sucks up a lot of memory for pretty superficial 'improvements' over XP. So what is better- 2GB and XP or 4GB and Vista?
And finally 7) Ive seen overclocked systems and specific systems under the gaming section, the gaming machines being cheaper...should I be going for gaming or overclocking?
Thanks for any help in advance and please forgive my incompetence! And apologies if Ive stuck this in the wrong forum!
