- 7 Jun 2010
I have been having big issues with Company of Heroes.
My RAM failed on my computer: So I upgraded the RAM and at the same time also upgraded the motherboard. Now I have done so Company of Heroes doesn't work, at all. Not only this I seem to be the only person I can find experiencing these errors.
CPU - QX6700 @ 3.0Ghz
RAM - OCZ DDR3 1600Mhz 8Gb
GPU - 8800GTS 640mb x 2 SLI
MoBo - MSI P7N Diamond
NOTE: This upgrade also caused the same problem with my already preinstalled Company or Heroes.
From the begging: Booted onto original OS, Windows 7 x64, already installed from before RAM failure. CoH would load but images and video were sometimes distorted as well as scratches appearing all over the screen. I thought this would be a HDD corruption as I had to reboot hundreds of times to install Windows 7 (Long story). Then tried re-installing CoH, turns out you cannot re-install or repair just uninstall. I tried uninstall and reinstall then CoH would crash on load, just after videos.
Next step: I installed a fresh copy of Windows 7 x64 Ultimate onto another new and blank HDD. Updated latest drivers, etc. not a single problem with hardware or compatability (Certainly not in Device Manager) and Windows says my hardware is performing perfectly. Installed CoH and exact same problem.
Step three: I then trowled around the internet for about a day, except for work, and came up with nothing. Decided to update the DirectX drivers, searched for DirectX10 as CoH dump file was saying it was running 9.0. Realised there is only a single DX web installer and ran that.
Step four: Success! CoH loads after the videos! Although the images are distorted in exactly the same way as they were on original install. Then, CoH crashes again after around 20-30 seconds in different places.
N.B/ During any of the installations I couldn't update CoH in game as it would crash before downloading more than a single Mb of the patch. Also CoH refused to let me patch the game manually as it says:
Or...
It maintains these errors and problems regardless of which operating system, CoH version or anything except hardware, DirectX and drivers.
If anybody understands the dump files I will post them below.
warnings.log:
ErrorLog
I have spent days trying to fix this but to no avail! As I said I cannot find anyone with similar problems and I have been scowering the internet. Though what is intresting to note from the warnings file is:
Snippet (warnings.log)
I feel like taking a sledgehammer to the thing!
Code:
An internal check has failed. Please contact THQ technical support for assistance (Error code: 10148)
Or...
Code:
This patch updates Company of Heroes version 2.101.0, but you have an unrecognised version installed. If logging into Relic Online to download the latest patch does not solve this problem you may need to reinstall Company of Heroes. (Error code: 10267)
warnings.log:
Code:
RELICCOH started at 2010-06-15 05:44
OS NT 5.1 (sp2.0) x64, 1024MB Physical Memory, 1024 Physical Available, 3980 Virtual Available
RUN-OPTIONS -relaunchmce
WORKING-DIR C:\Games\Company of Heroes
USER Jack Hammer
05:44:46.65 4 Logical Processors detected
05:44:46.65 Multithreading Enabled
05:44:46.65 THREAD: Hyper-Threading Technology Processors are not detected.
05:44:46.65 XTHREAD: Detected 4 core(s) with 4 hardware thread(s)
05:44:46.65 XTHREAD: Main thread now used as XThread 0
05:44:46.65 XTHREAD: Spawned thread on processor 1
05:44:46.65 XTHREAD: Spawned thread on processor 2
05:44:46.65 XTHREAD: Spawned thread on processor 3
05:44:46.65 MATHBOX -- Version=6, Cpu=unknown:f=6,m=15, Mode=SSE
05:44:46.65 NetworkManager::Create - creating network manager
05:44:46.65 NetFileAccessor::Open - error, unable to open or create file.
05:44:46.65 Skipping empty datastore login_cache.bin
05:44:46.65 Skipping empty datastore profile_cache.bin
05:44:46.65 Skipping empty datastore global_cache.bin
05:44:46.67 NetFileAccessor::Open - error, unable to open or create file.
05:44:46.67 Skipping empty datastore stats_cache.bin
05:44:46.67 Skipping empty datastore ping_cache.bin
05:44:46.67 Session::Initialize - info, initializing session object, using threads - [yes].
05:44:46.67 Session::InitializeTransport - info, initializing session transport...
05:44:46.67 NetZTransport::InitializeNetZSession - info, NetZ session initialized successfully.
05:44:46.67 Net::ThreadFunction - Entering network thread function...
05:44:46.67 WinsockTransport::Initialize - info, initializing Winsock2 ...
05:44:46.67 MessageInternal::CreateChannel: Created channel 47535450 (#1)
05:44:46.67 AutomatchInternal: Instantiating
05:44:46.67 Session::GetState - info, session's state changed to [3:STATE_ENUMERATING].
05:44:46.67 MessageInternal::CreateChannel: Created channel 534d5347 (#2)
05:44:46.67 MessageInternal::CreateChannel: Created channel 474d4343 (#3)
05:44:46.67 MessageInternal::CreateChannel: Created channel 474f424a (#4)
05:44:46.67 MessageInternal::CreateChannel: Created channel 4d4f444d (#5)
05:44:46.67 MessageInternal::DestroyChannel: Destroyed channel 534d5347 (#2)
05:44:46.67 MessageInternal::DestroyChannel: Destroyed channel 474d4343 (#3)
05:44:46.67 MessageInternal::DestroyChannel: Destroyed channel 474f424a (#4)
05:44:46.67 MessageInternal::DestroyChannel: Destroyed channel 4d4f444d (#5)
05:44:46.70 GAME -- Company Of Heroes, 2.100.0, Build 1674, Type live, Language english
05:44:46.70 GAME -- Available memory: 3071MB Physical RAM, 3069MB Pagefile, 4095 Virtual Address Space
05:44:46.70 SYSTEMCONFIG -- Failed to load configuration from 'userdata:configuration.lua'.
05:44:46.70 DLLDriverLinker -- Adding driver 'spDx10.dll'.
05:44:46.72 DLLDriverLinker -- Adding driver 'spDx9.dll'.
05:44:46.72 DLLDriverLinker -- 2 DLL drivers found.
05:44:46.84 SPDx10 -- Adapter [NVIDIA GeForce 8800 GTS]: 615MB dedicated video memory, 0MB dedicated system memory and 1279MB shared system memory.
05:44:50.26 DLLDriverLinker -- 2 DLL drivers found.
05:44:50.27 SPOOGE - Driver[DirectX10 Rendering Device] version[4,36]
05:44:50.27 GAME -- Resolution set to 1280x768 (fullscreen).
05:44:50.30 SPDx10 -- Adapter Description = NVIDIA GeForce 8800 GTS
05:44:50.30 SPDx10 -- Driver Vendor = 0x000010de Device = 0x00000193 SubSys = 0x042110de Rev = 0x000000a2
05:44:50.30 SPDx10 -- Driver Version Product = 0x0008 Version = 0x0011 SubVersion = 0x00 Build = 197.45
05:44:50.30 SPDx10 -- Driver LUID = 0x00000000-0x00009913
05:44:50.30 SPDx10 -- 615MB dedicated video memory, 0MB dedicated system memory and 1279MB shared system memory available.
05:44:50.30 SPDx10 -- NvAPI_EnumLogicalGPUs reported [2] logical GPUs, setting rendering to [1] GPU mode.
05:44:50.30 ShaderDatabase: using shader profile [ps40]
05:44:51.15 SPDx10 -- Gamma Caps - Scale/Offset supported: no, Max: 1.00, Min: 0.00, Number of Control Points: 256.
05:44:51.24 SPDx10 -- Gamma Caps - Scale/Offset supported: no, Max: 1.00, Min: 0.00, Number of Control Points: 256.
05:44:51.27 FILESYSTEM -- filepath failure, missing alias 'TOOLSDATA:autoloddecimator.lua'
05:44:51.77 GameObjLoader 0e308a78 - resetting counters
05:44:51.77 GameObjLoader 0e308a78 - Created loader
05:44:51.77 GameObjLoader 0e308bd8 - resetting counters
05:44:51.77 GameObjLoader 0e308bd8 - Created loader
05:44:51.77 GAME -- Beginning FE
05:44:51.77 UIFrontEnd - Loading Front End
05:44:51.88 SOUND -- Initializing ...
05:44:51.92 INNIMapDCA Key not found: sp_speechducker::time
05:44:52.01 SOUND -- Initialization completed!
05:44:52.01 UIFrontEnd - Initializing Forms
05:44:52.61 CampaignFilter::BindFilterSpecificWidgets()
05:44:52.63 APP -- Resetting fp control word.
05:44:52.63 DivXMovie -- ERROR 1006: Error occured while reading the input file.!
05:44:52.63 DivXMovie -- Could not open DivX movie 'ENGINE\MOVIES\THQx.divx' because an error occured.
05:44:52.63 MOV -- Movie does not exist movies:ThqIntro.lua
05:44:52.63 NetworkManager::DispatchEvents() - WARNING! Time between calls was 5959 ms
05:44:52.64 Activating screen: AppLoadingForm
05:44:52.67 MOD -- (mod manager) RelicCOH, 1.0
05:44:54.59 WW2Mod -- PropertyBagManager Loaded in 1.849000s
05:44:54.66 GAME -- Loaded campaign 'Invasion of Normandy' (DATA:SCENARIOS\SP\COH.CAMP) with 15 missions
05:44:54.66 GAME -- Loaded campaign 'Liberation of Caen' (DATA:SCENARIOS\SP\CXP1.CAMP) with 9 missions
05:44:54.66 GAME -- Loaded campaign 'Operation Market Garden' (DATA:SCENARIOS\SP\CXP2.CAMP) with 8 missions
05:44:54.75 GAME -- Using player profile JACKHAMMER-PC
05:44:56.03 Dx10Program : Unable to find shader script for 'fxshader_multiply' in the ShaderDatabase.
05:44:56.44 Dx10Program : Unable to find shader script for 'fxshader_depthadditive' in the ShaderDatabase.
05:44:57.63 Connecting to server: cohlive.quazal.net:30260
05:44:57.63 RendezvousManager: CreateSession - starting profile=Guest login
05:45:00.84 RendezvousManager: Login complete and successfull
05:45:00.86 RendezvousManager initialized
05:45:01.91 Current server english:live version is 300.0, client is 100.0
05:45:02.59 Current patch is http://64.147.167.66/relic/coh/retail/EN_2100-2101_Patch.exe, size=143894270 crc=0
05:45:02.61 OnConnect: successful connection established, enabling reconnect
05:45:02.61 OnConnect: this wasnt a reconnect, no need for autologin
05:45:02.65 Activating screen: FEMovie
05:45:02.65 Activating screen: OnlineWidget
05:45:02.65 Activating screen: RelicOnlineLogin
05:45:02.67 Activating screen: MessageBoxPopup
05:45:02.67 ScreenManager - Flushing recursively, due to activated screens during the previous flush, flush number: 1
05:45:03.76 Activating screen: DownloadProgress
05:45:03.76 DownloadAsync::LoadResumeFile - info, partial download found, resume position [0].
05:45:03.76 IsSpaceAvailable - info, disk [C:\USERS\JACK HAMMER\DOCUMENTS\MY GAMES\COMPANY OF HEROES\PATCH] has [279775895552] bytes of disk space available to user, we need [143894269].
05:45:03.76 DownloadAsync::Initialize - info, initializing HTTP download session, URL= [http://64.147.167.66/relic/coh/retail/EN_2100-2101_Patch.exe], starting position= [0].
05:45:03.76 DownloadAsync - HTTP host name= [64.147.167.66] resolved to [64.147.167.66].
05:45:03.80 DownloadAsync::StateInitialized - info, connecting to [64.147.167.66], port [80].
05:45:03.99 DownloadAsync::StateConnected - info, connected to [64.147.167.66], sending HTTP GET request [GET http://64.147.167.66/relic/coh/retail/EN_2100-2101_Patch.exe HTTP/1.0
Range: bytes=0-
Accept: */*
Connection: close
05:45:04.17 DownloadAsync::StateSendingHTTPGetRequest - info, HTTP server response, status= [206], content length= [143894270] bytes, full size= [143894270] bytes, support ranges= [yes].
ErrorLog
Code:
RelicCOH.exe caused an Access Violation in module DivxDecoder.dll at 0023:01093410.
Error occurred at 6/15/2010 05:37:58.
RelicCOH.exe, run by Jack Hammer.
Microsoft Windows XP [ver=5.1]
4 processor(s), type 586.
1024 MBytes physical memory.
Read from location 29765000 caused an access violation.
MiniDump saved to file 'C:\Users\Jack Hammer\Documents\My Games\Company of Heroes\6-15-2010_05_37_58_MiniDump.dmp'
Registers:
EAX=0427fdac CS=0023 EIP=01093410 EFLGS=00210246
EBX=00000001 SS=002b ESP=0108f8ec EBP=29765000
ECX=0000001f DS=002b ESI=0425ed40 FS=0053
EDX=00000000 ES=002b EDI=0427f500 GS=002b
Bytes at CS:EIP:
8b 4d 00 89 44 24 10 89 08 8b 4c 24 10 8b 01 0f
Call Stack:
0x01093410: UnInitializeDivxDecoder (C:\Games\Company of Heroes\DivxDecoder.dll)
0x01091A6A: UnInitializeDivxDecoder (C:\Games\Company of Heroes\DivxDecoder.dll)
0x010911DD: DivxDecode (C:\Games\Company of Heroes\DivxDecoder.dll)
0x003920B1: DivxDoFrame (C:\Games\Company of Heroes\DivxMediaLib.dll)
Stack dump:
0108f97c: 003a2f20 0e2fbc90 7349f8cd 007f0000 413722ae 00002cb5 00000000 0716d7e4
0108f99c: 0108f9d0 00000000 0716bb50 0716d7e4 099f1410 00000000 089341c8 00000000
0108f9bc: 0108f9d0 734a7cab 0716bb50 099f1410 00000000 0108fa24 734c2407 099f1410
0108f9dc: 00000000 00000001 734c2425 00000009 0716bb00 0716dc48 0108fa4c 006eef40
0108f9fc: 0108fa88 0108fa38 18379a38 c0000000 4026e455 00670198 413722ae 011243e1
0108fa1c: 3c8b4396 17f3b854 18379a38 0108fa88 18379a38 00000000 3c8b4396 00000000
0108fa3c: 3f800000 00000000 3f800000 0108faa4 17f3b858 011253e0 0108fa88 0108fad8
0108fa5c: 0ff94068 0108fabc 0112cc26 0e946148 0ff94068 0108faec 00000001 00000000
0108fa7c: 00000001 00000001 0108fab4 3c8b4396 00000000 3f800000 00000000 3f800000
0108fa9c: 00000000 3f800000 00000000 3f800000 00000000 00000000 03f563c8 3f800000
0108fabc: 0108fb0c 0112cd55 0108fad8 17064028 1706403c 3f800000 3f800000 3c8b4396
0108fadc: 00000000 3f800000 00000000 3f800000 00000000 3f800000 00000000 3f800000
0108fafc: 00000004 00000000
Module list: names, addresses, sizes, time stamps and file times:
C:\Games\Company of Heroes\Debug.dll, loaded at 0x00140000 - 43328 bytes - 46df49ab - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Memory.dll, loaded at 0x00170000 - 63296 bytes - 46df49b1 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Filesystem.dll, loaded at 0x00250000 - 254784 bytes - 46df49da - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Platform.dll, loaded at 0x00290000 - 126784 bytes - 46df49c4 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\STLPort.dll, loaded at 0x002c0000 - 439616 bytes - 44d17547 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Util.dll, loaded at 0x00330000 - 276800 bytes - 46df49fd - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\DivxMediaLib.dll, loaded at 0x00390000 - 86016 bytes - 40299282 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\FileParser.dll, loaded at 0x003b0000 - 86016 bytes - 40299281 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Localizer.dll, loaded at 0x003d0000 - 66880 bytes - 46df4a38 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\RelicCOH.exe, loaded at 0x00400000 - 8558912 bytes - 46df4f77 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\DivxDecoder.dll, loaded at 0x01090000 - 413696 bytes - 40299280 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\UserInterface.dll, loaded at 0x01100000 - 376128 bytes - 46df4a8f - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Shark.dll, loaded at 0x01290000 - 416064 bytes - 46df4a2f - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\libacml_mp_dll.dll, loaded at 0x01300000 - 7127040 bytes - 453f3111 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\libifcoremd.dll, loaded at 0x019d0000 - 643072 bytes - 4383e12d - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\libmmd.dll, loaded at 0x01a80000 - 2314332 bytes - 438e6805 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\libguide40.dll, loaded at 0x01cc0000 - 196608 bytes - 431878e7 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\MathBox.dll, loaded at 0x01d00000 - 667968 bytes - 46df4a55 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\XThread.dll, loaded at 0x01db0000 - 34624 bytes - 46df49e1 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Spooge.dll, loaded at 0x01dd0000 - 131904 bytes - 46df4a67 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\SimEngine.dll, loaded at 0x01e10000 - 966464 bytes - 46df4aa5 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\Profiler.dll, loaded at 0x02310000 - 20800 bytes - 46df49c9 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\PlatHook.dll, loaded at 0x03c00000 - 11584 bytes - 46d9e6ea - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\spDx10.dll, loaded at 0x05ee0000 - 1221952 bytes - 46df4ac1 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\MilesRedist\msseax.flt, loaded at 0x06010000 - 112640 bytes - 445fd238 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\MilesRedist\msssrs.flt, loaded at 0x06070000 - 42496 bytes - 445fd205 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\spDx9.dll, loaded at 0x06d00000 - 1094976 bytes - 46df4af5 - file date is 6/15/2010 04:00:48
C:\Windows\system32\d3dx9_30.dll , loaded at 0x06e10000 - 2388176 bytes - 442d83c4 - file date is 3/31/2006 12:40:58
C:\Windows\system32\nvapi.dll , loaded at 0x0b110000 - 1296488 bytes - 4bb7ee09 - file date is 4/3/2010 22:55:32
C:\Games\Company of Heroes\LuaConfig.dll, loaded at 0x10000000 - 209728 bytes - 46df49e9 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\WW2Mod.dll, loaded at 0x190e0000 - 5913408 bytes - 46df4d21 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\mss32.dll, loaded at 0x21100000 - 379904 bytes - 445fd203 - file date is 6/15/2010 04:00:48
C:\Games\Company of Heroes\MilesRedist\mssds3d.flt, loaded at 0x22300000 - 39936 bytes - 445fd238 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\MilesRedist\mssdolby.flt, loaded at 0x23000000 - 28160 bytes - 445fd205 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\MilesRedist\mssdsp.flt, loaded at 0x24100000 - 113664 bytes - 446516d3 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\MilesRedist\mssvoice.asi, loaded at 0x26400000 - 216576 bytes - 445fd27a - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\MilesRedist\mssmp3.asi, loaded at 0x26f00000 - 150016 bytes - 445fd232 - file date is 6/15/2010 04:00:50
C:\Games\Company of Heroes\dbghelp.dll, loaded at 0x73330000 - 1030144 bytes - 44b01174 - file date is 6/15/2010 04:00:48
C:\Windows\system32\nvwgf2um.dll , loaded at 0x73450000 - 4503144 bytes - 4bb7e08d - file date is 4/3/2010 22:55:32
C:\Windows\system32\rasadhlp.dll , loaded at 0x739b0000 - 11776 bytes - 4a5bdad6 - file date is 7/14/2009 02:16:14
C:\Windows\System32\fwpuclnt.dll , loaded at 0x739c0000 - 216576 bytes - 4a5bda07 - file date is 7/14/2009 02:15:22
C:\Windows\system32\pnrpnsp.dll , loaded at 0x73a00000 - 65024 bytes - 4a5bdaf6 - file date is 7/14/2009 02:16:14
C:\Windows\system32\napinsp.dll , loaded at 0x73a20000 - 52224 bytes - 4a5bda6d - file date is 7/14/2009 02:16:04
C:\Windows\System32\winrnr.dll , loaded at 0x73a30000 - 20992 bytes - 4a5bdb44 - file date is 7/14/2009 02:16:20
C:\Windows\system32\DNSAPI.dll , loaded at 0x73a40000 - 269824 bytes - 4a5bd9d9 - file date is 7/14/2009 02:15:14
C:\Windows\system32\NLAapi.dll , loaded at 0x73a90000 - 51712 bytes - 4a5bda7c - file date is 7/14/2009 02:16:04
C:\Windows\system32\avrt.dll , loaded at 0x73aa0000 - 14336 bytes - 4a5bd998 - file date is 7/14/2009 02:15:00
C:\Windows\system32\winbrand.dll , loaded at 0x73ab0000 - 12800 bytes - 4a5bdb39 - file date is 7/14/2009 02:16:20
C:\Windows\system32\NTDSAPI.dll , loaded at 0x73ac0000 - 90112 bytes - 4a5bdade - file date is 7/14/2009 02:16:12
C:\Windows\system32\wbem\fastprox.dll, loaded at 0x73ae0000 - 605696 bytes - 4a5bd9de - file date is 7/14/2009 02:15:22
C:\Windows\system32\wbem\wbemsvc.dll, loaded at 0x73b80000 - 47616 bytes - 4a5bdb30 - file date is 7/14/2009 02:16:18
C:\Windows\system32\RpcRtRemote.dll, loaded at 0x73b90000 - 45568 bytes - 4a5bc6b3 - file date is 7/14/2009 02:16:14
C:\Windows\system32\rsaenh.dll , loaded at 0x73ba0000 - 242936 bytes - 4a5bdae0 - file date is 7/14/2009 02:17:56
C:\Windows\system32\CRYPTSP.dll , loaded at 0x73be0000 - 78848 bytes - 4a5bda3d - file date is 7/14/2009 02:15:08
C:\Windows\system32\wbemcomn.dll , loaded at 0x73c00000 - 362496 bytes - 4a5bdb2a - file date is 7/14/2009 02:16:18
C:\Windows\SysWOW64\d3d11.dll , loaded at 0x73c60000 - 522752 bytes - 4a5bd9a6 - file date is 7/14/2009 02:15:08
C:\Windows\SysWOW64\d3d10_1core.dll, loaded at 0x73cf0000 - 217088 bytes - 4a5bd9a2 - file date is 7/14/2009 02:15:08
C:\Windows\SysWOW64\d3d10_1.dll , loaded at 0x73d30000 - 161792 bytes - 4a5bd9a1 - file date is 7/14/2009 02:15:08
C:\Windows\system32\d3d9.dll , loaded at 0x73d60000 - 1826816 bytes - 4a5bd9a9 - file date is 7/14/2009 02:15:10
C:\Windows\system32\d3dx10_33.dll , loaded at 0x73f30000 - 443752 bytes - 45f8d53d - file date is 3/15/2007 16:57:58
C:\Windows\system32\dxgi.dll , loaded at 0x73fa0000 - 507392 bytes - 4a5bda0c - file date is 7/14/2009 02:15:14
C:\Windows\system32\d3d10.dll , loaded at 0x74030000 - 1030144 bytes - 4a5bd9a0 - file date is 7/14/2009 02:15:08
C:\Windows\SysWOW64\gameux.dll , loaded at 0x74140000 - 2576384 bytes - 4a5bd9db - file date is 7/14/2009 02:15:24
C:\Windows\system32\wbem\wbemprox.dll, loaded at 0x743d0000 - 29184 bytes - 4a5bdb2f - file date is 7/14/2009 02:16:18
C:\Windows\SysWOW64\dxdiagn.dll , loaded at 0x743e0000 - 210432 bytes - 4a5bda0b - file date is 7/14/2009 02:15:14
C:\Windows\system32\d3d8thk.dll , loaded at 0x74420000 - 11264 bytes - 4a5bd9a8 - file date is 7/14/2009 02:15:10
C:\Windows\system32\d3d10core.dll , loaded at 0x74430000 - 190464 bytes - 4a5bd9a3 - file date is 7/14/2009 02:15:08
C:\Windows\SysWOW64\wer.dll , loaded at 0x74470000 - 377856 bytes - 4a5bdb29 - file date is 7/14/2009 02:16:20
C:\Windows\SysWOW64\XmlLite.dll , loaded at 0x744d0000 - 180224 bytes - 4a5bdb42 - file date is 7/14/2009 02:16:22
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll, loaded at 0x74500000 - 1624576 bytes - 4a5bd976 - file date is 7/14/2009 02:03:52
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_none_421189da2b7fabfc\COMCTL32.dll, loaded at 0x74690000 - 1680896 bytes - 4a5bd976 - file date is 7/14/2009 02:03:52
C:\Windows\System32\wshtcpip.dll , loaded at 0x74830000 - 9216 bytes - 4a5bdb5a - file date is 7/14/2009 02:16:22
C:\Windows\system32\mswsock.dll , loaded at 0x74840000 - 232448 bytes - 4a5bda77 - file date is 7/14/2009 02:15:52
C:\Windows\system32\SortServer2003Compat.dll, loaded at 0x74880000 - 38400 bytes - 4a5bc022 - file date is 7/14/2009 02:16:16
C:\Windows\system32\SHUNIMPL.DLL , loaded at 0x74890000 - 10240 bytes - 4a5bc588 - file date is 7/14/2009 02:16:16
C:\Windows\AppPatch\AcXtrnal.DLL , loaded at 0x748a0000 - 211968 bytes - 4a5bd98a - file date is 7/14/2009 02:14:54
C:\Windows\AppPatch\AcGenral.DLL , loaded at 0x74b00000 - 2175488 bytes - 4a5bd97a - file date is 7/14/2009 02:14:52
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCR80.dll, loaded at 0x74d20000 - 632656 bytes - 4a2752ff - file date is 6/10/2009 22:23:12
C:\Windows\system32\faultrep.DLL , loaded at 0x74dc0000 - 320512 bytes - 4a5bd9df - file date is 7/14/2009 02:15:22
C:\Windows\system32\AUDIOSES.DLL , loaded at 0x75130000 - 195584 bytes - 4a5bd97e - file date is 7/14/2009 02:14:58
C:\Windows\system32\WINNSI.DLL , loaded at 0x751b0000 - 16896 bytes - 4a5bdb43 - file date is 7/14/2009 02:16:20
C:\Windows\system32\IPHLPAPI.DLL , loaded at 0x751c0000 - 103936 bytes - 4a5bda1b - file date is 7/14/2009 02:15:34
C:\Windows\System32\MMDevApi.dll , loaded at 0x75230000 - 213504 bytes - 4a5bda29 - file date is 7/14/2009 02:15:42
C:\Windows\system32\dwmapi.dll , loaded at 0x75270000 - 67072 bytes - 4a5bda07 - file date is 7/14/2009 02:15:14
C:\Windows\system32\MPR.dll , loaded at 0x752c0000 - 64000 bytes - 4a5bda36 - file date is 7/14/2009 02:15:42
C:\Windows\system32\USERENV.dll , loaded at 0x752e0000 - 79360 bytes - 4a5bdb31 - file date is 7/14/2009 02:16:18
C:\Windows\AppPatch\AcLayers.dll , loaded at 0x75300000 - 559616 bytes - 4a5bd97b - file date is 7/14/2009 02:14:52
C:\Windows\system32\apphelp.dll , loaded at 0x75390000 - 292352 bytes - 4a5bd9b6 - file date is 7/14/2009 02:14:54
C:\Windows\system32\profapi.dll , loaded at 0x753e0000 - 31744 bytes - 4a5bbf41 - file date is 7/14/2009 02:16:14
C:\Windows\system32\sfc_os.DLL , loaded at 0x753f0000 - 40960 bytes - 4a5bdb02 - file date is 7/14/2009 02:16:16
C:\Windows\system32\MSACM32.dll , loaded at 0x75400000 - 72192 bytes - 4a5bda4e - file date is 7/14/2009 02:15:44
C:\Windows\System32\PROPSYS.dll , loaded at 0x75420000 - 988160 bytes - 4a5bdacb - file date is 7/14/2009 02:16:14
C:\Windows\system32\UxTheme.dll , loaded at 0x75520000 - 245760 bytes - 4a5bdb3c - file date is 7/14/2009 02:11:26
C:\Windows\system32\sfc.dll , loaded at 0x755a0000 - 2560 bytes - 4a5bdb01 - file date is 7/14/2009 02:10:24
C:\Windows\system32\samcli.dll , loaded at 0x755b0000 - 50688 bytes - 4a5bdadb - file date is 7/14/2009 02:16:14
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCP80.dll, loaded at 0x755c0000 - 554816 bytes - 4a275370 - file date is 6/10/2009 22:23:12
C:\Windows\system32\VERSION.dll , loaded at 0x75770000 - 21504 bytes - 4a5bdb2b - file date is 7/14/2009 02:16:18
C:\Windows\system32\POWRPROF.dll , loaded at 0x757d0000 - 145408 bytes - 4a5bdb0c - file date is 7/14/2009 02:16:14
C:\Windows\system32\WINMM.dll , loaded at 0x75800000 - 194048 bytes - 4a5bdb42 - file date is 7/14/2009 02:16:20
C:\Windows\system32\DSOUND.dll , loaded at 0x75840000 - 453632 bytes - 4a5bd9fd - file date is 7/14/2009 02:15:14
C:\Windows\system32\WINSPOOL.DRV , loaded at 0x758c0000 - 319488 bytes - 4a5bdb4b - file date is 7/14/2009 02:14:10
C:\Windows\syswow64\CRYPTBASE.dll , loaded at 0x759e0000 - 36864 bytes - 4a5bbf41 - file date is 7/14/2009 02:15:08
C:\Windows\syswow64\SspiCli.dll , loaded at 0x759f0000 - 96768 bytes - 4b21f681 - file date is 12/11/2009 08:36:34
C:\Windows\syswow64\USP10.dll , loaded at 0x75b50000 - 627200 bytes - 4a5bdb32 - file date is 7/14/2009 02:16:18
C:\Windows\syswow64\RPCRT4.dll , loaded at 0x75c10000 - 662528 bytes - 4a5bdb3b - file date is 7/14/2009 02:11:24
C:\Windows\syswow64\MSCTF.dll , loaded at 0x75db0000 - 828928 bytes - 4a5bda69 - file date is 7/14/2009 02:15:44
C:\Windows\syswow64\urlmon.dll , loaded at 0x75e80000 - 1224704 bytes - 4a5bdb2c - file date is 7/14/2009 02:16:18
C:\Windows\syswow64\ADVAPI32.dll , loaded at 0x75fc0000 - 640000 bytes - 4a5bd97e - file date is 7/14/2009 02:14:54
C:\Windows\syswow64\LPK.dll , loaded at 0x76060000 - 25600 bytes - 4a5bdb3b - file date is 7/14/2009 02:11:24
C:\Windows\syswow64\SETUPAPI.dll , loaded at 0x76070000 - 1668608 bytes - 4a5bdafe - file date is 7/14/2009 02:16:16
C:\Windows\syswow64\msvcrt.dll , loaded at 0x76210000 - 690688 bytes - 4a5bda6f - file date is 7/14/2009 02:15:52
C:\Windows\syswow64\USER32.dll , loaded at 0x762c0000 - 833024 bytes - 4a5bdb3c - file date is 7/14/2009 02:11:26
C:\Windows\syswow64\SHELL32.dll , loaded at 0x763c0000 - 12867072 bytes - 4b7cec9c - file date is 2/18/2010 08:34:02
C:\Windows\syswow64\OLEAUT32.dll , loaded at 0x770a0000 - 571904 bytes - 4a5bdaca - file date is 7/14/2009 02:16:14
C:\Windows\syswow64\iertutil.dll , loaded at 0x77130000 - 2058240 bytes - 4a5bda0c - file date is 7/14/2009 02:15:30
C:\Windows\syswow64\CLBCatQ.DLL , loaded at 0x77330000 - 522240 bytes - 4a5bd9b1 - file date is 7/14/2009 02:15:04
C:\Windows\syswow64\CFGMGR32.dll , loaded at 0x773c0000 - 145920 bytes - 4a5bd9a6 - file date is 7/14/2009 02:15:04
C:\Windows\syswow64\KERNELBASE.dll , loaded at 0x773f0000 - 269824 bytes - 4a5bdbdf - file date is 7/14/2009 02:11:24
C:\Windows\syswow64\IMAGEHLP.dll , loaded at 0x77440000 - 154624 bytes - 4a5bd9fc - file date is 7/14/2009 02:15:32
C:\Windows\syswow64\ole32.dll , loaded at 0x77470000 - 1412608 bytes - 4a5bdac7 - file date is 7/14/2009 02:16:14
C:\Windows\syswow64\GDI32.dll , loaded at 0x775d0000 - 310784 bytes - 4a5bdb38 - file date is 7/14/2009 02:11:22
C:\Windows\syswow64\SHLWAPI.dll , loaded at 0x77660000 - 350208 bytes - 4a5bdb05 - file date is 7/14/2009 02:16:16
C:\Windows\syswow64\CRYPT32.dll , loaded at 0x776c0000 - 1151488 bytes - 4a5bda39 - file date is 7/14/2009 02:15:08
C:\Windows\syswow64\NSI.dll , loaded at 0x777e0000 - 8704 bytes - 4a5bdad9 - file date is 7/14/2009 02:16:12
C:\Windows\syswow64\kernel32.dll , loaded at 0x777f0000 - 836608 bytes - 4a5bdbde - file date is 7/14/2009 02:11:24
C:\Windows\system32\IMM32.DLL , loaded at 0x778f0000 - 119808 bytes - 4a5bdb39 - file date is 7/14/2009 02:11:22
C:\Windows\syswow64\DEVOBJ.dll , loaded at 0x779d0000 - 64512 bytes - 4a5bd9c5 - file date is 7/14/2009 02:15:12
C:\Windows\SysWOW64\sechost.dll , loaded at 0x779f0000 - 92160 bytes - 4a5bdb04 - file date is 7/14/2009 02:16:14
C:\Windows\syswow64\WS2_32.dll , loaded at 0x77a10000 - 206336 bytes - 4a5bdb4a - file date is 7/14/2009 02:16:22
C:\Windows\syswow64\WINTRUST.dll , loaded at 0x77a50000 - 172032 bytes - 4b39a768 - file date is 12/29/2009 07:55:36
C:\Windows\syswow64\MSASN1.dll , loaded at 0x77e50000 - 34816 bytes - 4a98d038 - file date is 8/29/2009 07:57:32
C:\Windows\SysWOW64\ntdll.dll , loaded at 0x77e80000 - 1289712 bytes - 4a5bdb3b - file date is 7/14/2009 02:17:52
Code:
