- 10 Apr 2004
Hi Guys,
Hit a brick wall over the last three days. I'm working through this guide: http://lime-technology.com/wiki/index.php/Installing_unRAID_5.0_on_a_full_Slackware_Distro. I'm down to the 'Modify the unRAID kernel config' part.
I've run 'make localyesconfig' and every combination I can think of with no success.
Here are my:
.config
lspci
dmesg
lsmod
I however keep getting the following error:
Disk is a Crucial M4 on the SATA 6gbps port on my Asus P8B WS.
The UnRAID kernel and the default 14.1 kernel boot perfectly, so I'm missing something.
Can someone who knows what they are doing more-so-than me, work out what is wrong and then explain?
Thanks!!!
Here are my:
.config
lspci
dmesg
lsmod
Thanks!!!
Try again, make sure you don't wipe their .config file. I would do a diff between what you enable and what was there before (copy it off .config first) and then see what you've actually enabled in `make menuconfig`
