Help - Computer Cases
8 Aug 2014
United Kingdom
Hi All,
Bought a g10 cooler for my 290X and a Corsair H55 Cooler so I can finally liquid cool my GPU.
Unfortunately I have a Corsair Spec-01 case and cannot fit in the cooler in along with my H60 which is cooling my CPU :/ boo!
I figured it time to buy a new case and was looking for some help with finding a roomy case with plenty of space for my 7 fans H60 and H75 (replaced the H55 as it was broken on delivery) and also my beasty 290X reference design by XFX.
Any help would be appreciated.
Thanks
Pretty much any full tower case will fit that lot. If you're after something a bit smaller Phanteks do a few good ATX cases and NZXT do the H440 which is excellent (doesn't have an optical drive bay though)
I have the 540 its nice and easy to get a clean build inside with the 2 compartments and has more than enough space for what you need.
I have a h100 in the roof and used to have a 120mm aio in the front.
