Hi guys!
so I just moved into a new place, plugged my pc in (which was working fine previously), it was connected to a surge protected extension lead then into the wall.
I switch on my pc, I see a lamp across the room go out and it won't turn on.
I got to my circuit breakers and see it has flipped to off. So I switch it back to 'on' again and head to my pc.
I try turning it on and nothing. the other devices connected to the surge connector extension lead work, including a monitor. So I grab the kettle lead for the monitor and try that (in case the fuse in my pc kettle lead has blown), but the pc still won't turn on.
there is no light on my motherboard and there was no loud bang when I turned on my pc. I've tried a different wall socket and no luck. I've yet to try it in an entirely different room, but I don't think that would make a difference.
PLEASE help me!! What do you think it is? What would have caused it?
Be gentle...
Be gentle...
