Hi there,
Woke up this morning and my computer won't switch on and i am wondering what the problem is. This is after I had put into into standby (Vista) last night. I have tried taking the plug out the back, and putting it in again...to no avail.
My Hardware is:
Hiper 580W Modular
DFI Ultra-D (939)
Opteron 165
2x1GB Corsair Ram
X1900XT
250GB SATA Drive
DVDRW IDE
When the power cable is plugged in at the back, the red light on the hiper comes on to signify there is power going in (normally a red light there). The Hiper fan is on constantly at a pretty low pace.
There is no lights on my DFI Mobo when there normally is IIRC.
I have tried unplugging everything but the mobo and trying to switch it on with no avail. I have tried switching it on via the on button on the mobo to no avail.
What should i try next?
Thanks.
My Hardware is:
Hiper 580W Modular
DFI Ultra-D (939)
Opteron 165
2x1GB Corsair Ram
X1900XT
250GB SATA Drive
DVDRW IDE
Thanks.
Check the power connections between the PSU and the board and then search for Hiper PSU problem in google, it's well known that the Hipers have a higher rate of failure than most people are comfortable with. I'm betting if you swap the PSU you may be lucky
