- 12 Jun 2008
im quite new to the concept of overlcoking but i kind of know my way around it, but i entered some settings earlier on and now the computer wont seem to respond at all, its acting very strangely
at first the bios would not post, so i cleared the CMOS by placing a screwdriver on the pins to short it out
i then turned on the PC, it posted and come up with an error message about the CMOS and i had to choose a profile, which i did - i chose "default settings"
however after pressing enter, and trying to reboot wit the settings the computer then does not POST, it will only POST when i clear the CMOS again, it does this for any of the profiles that i chose
any help would be greatly appreciated, is there something im missing, and have i potentially damaged any of the components?
My computer is:
gigabyte GA-MA78GM-SH2
4gb ocz reaper ram @ 800mhz
amd athlon 64x2 3.0ghz
9600GT
the settings that i used last when the problem started were:
HTT @ 800mhz
FSB: 280 mhz
multiplier @ 12
ram: fsb ratio was 4
cpu vcore was 1.4v
any help would be greatly appreciated, im stuck and im not sure what to do now
My computer is:
9600GT
HTT @ 800mhz
FSB: 280 mhz
multiplier @ 12
cpu vcore was 1.4v
