No idea whats up guess theres always something with new computers....
Was working fine wiped the sweat off my head then realised when I came to shut down after installing windows that it booted straight back up... so thought must have clicked restart tried again same thing and again. Even if i power off in the bios which instantly shuts down the pc few secs later the pc starts back up again.
Any body got any clues ?
Sys spec,
GA-P35C-DSR3
2 Gigs 6400 ram
Geforce 8600
Q6600 (Zalman 9700 led cooler)
Enermax 535w Psu
I thought it was the front panel wired up wrong but I double checked through trial and error so it doesnt seem to be that.
I noticed in the bios my ram timings where wrong 5 - 5 - 5 - 18 instead of 4 - 4 - 4 - 12 but it doesnt say what voltage the ram is currently at so didnt wanna risk it not booting up at all. I changed the ddr v to +0.1 which I think is 1.9 from 1.8 and the timings down to 4 - 4 - 4 -12 but no luck....
Just gives settings to change the V +1 +2 +3 +4 but it doesnt say the current V in the bios ><. In Easytune it does say though that my Ram is set at 1.9v which is corret for my ram just timings are off.
I updated the Mboard bios to F4b which is the latest version I could find.
My PSU has a 10/12 pin adaptor plus an 12v for the cpu my mboard says either 10 or 12 pin so i plugged all of them in the 12 pin and the 12v for the cpu, that ok ?
Please help....
fishy
Sys spec,
GA-P35C-DSR3
2 Gigs 6400 ram
Geforce 8600
Enermax 535w Psu
Please help....
fishy
