Help configuring HP switch
  • Thread starter Thread starter Deleted member 651465
  • Start date Start date
Hey all,
When initially configuring my procurve, it asked for the gateway ip.
I set this to the ip of my router, because I wasn't sure what to set it as. Now, if I visit the switch ip (192.168.1.1) I get nothing. No login screen.
Essentially I can't log in to manage it, so I'm wondering if I should have set the gateway ip, to the same value as the switch ip?
Also.. If I turn my router to bridge mode, can I make the switch give out the static ips (I have static now, via the modem) and do NAT.
As you can tell I'm a networking n00b, so be gentle :p
Try manually configuring your computers IP address to say, 192.168.1.2 and then plug it into the switch directly. Navigate to 192.168.1.1 and see if you can access the page.
