- 30 Nov 2017
Hi, I have an ASUS Z370 TUF PLUS GAMING mobo, my case is very old, a Foxconn Diabolic TH202 (https://www.newegg.com/Product/Product.aspx?Item=N82E16...) (http://www.hardcoreware.net/reviews/review-190-1.htm).
This case has a front panel which has plugs for headphones and a mic, what I really need is a mic, headphones would be a plus.
The manual has a legend of each pin on its AAFP (10-1 pin), but I don't know where does each cable of my case's front panel module goes. I will include pics of the manual and the actual cables on the case.
Mobo manual: https://imgur.com/MR9BEbG
AAFP connector: https://imgur.com/ncTnwWy
Case's MIC cables: https://imgur.com/FPeNrqF
Case's HP cables: https://imgur.com/xo3R1l4
Case's other cables (i assume they are for a firewire connection): https://imgur.com/M6VBQ4F
Ultimately, can someone tell me where to connect each cable, where in the AAFP connector.
Thanks
Thanks
