HELP: Connecting PSU to mobo!
6 Jan 2011
I've been building my new rig for the last three hours and thought I'd made it to the finish line without asking a simple question. That's when I saw all the connectors on my PSU.
So basically, I'm running a 2500k through an msi p67 gd645 via a CM 690 II Advanced. My PSU is an Antec TruePower New 650w (modular). So far I have connected two of the fans from the case and two fans va a splitter to the mobo through Sys Fan1, 2, and 3. One of the Sys fans is blocked off by my GPU (GTX 460) so I'm looking at connecting that through a molex on the PSU.
...Here's the problem though: I don't know what the hell I'm talking about. I understand I should be looking for some kind of adapter but I can't see anything. The above mentioned fans are all 3 pins while the (unused) CPU fan is 4 pin.
I'm not too bothered about missing a fan at the moment as all I really want is to power on and run an installation of windows. So can anyone tell me what connects with what on my mobo as I don't really udnerstand the votages and am afraid of frying something.
Cheers in advance :rolleyes:
You shouldn't be able to fry anything realey as the plugs are different shapes to prevent you doing that ,worst thing you could do is not plug somthing in.
I wouldn't worry to much about 1 case fan you can do that later just make sure you have the 24 pin and 4/8 pin to the MB and that the cpu fan is pluged in
