Picture:
http://benchmarkreviews.com/images/reviews/motherboards/P8P67-EVO/ASUS-P8P67-EVO-Motherboard-Top.jpg
Using Zalman Z9 Plus case.
This is my first build and as such I am far from an expert when it comes to connecting all the wires up, so I was wondering if you could help me get through it step by step.
1. I have connected the PLED, IDE_LED, PWRSW and the RESET pins into the far bottom right 20-8 pin panel, and believe I have these connected correctly.
Now I'm on to the USB connections for the USB 2.0 slots on the front of the case. I am thinking that the two connectors that I have go into the blue sockets at the bottom-center of the MB.
Now, they each have different numbers underneath them: USB1314 USB1112 USB910 respectively.
Does it matter which ones I connect the front case's USB slots into?
