Not me.
I have used WD200, Seagate 250, Hitachi 80GB, Maxtor 160GB and at this time, I am running a 36GB Raptor, however, there is little real difference between them all.
Do you recon there could be somethign with the SATA on it then?
There are 3 controlers... Well, 2 controlers, one with 2 ports and another with 4.
I dont think there will be any difference in performance, but the purple one seems to be the 2-port one, and the 4 port is the orange ones.
I am using the seond from the top of the orange ports, as this come up as device 0.
I will swap the drive over to start up on the others in a bit to see if there is any true gain, but as of about 3 hours ago, I threw on Win2K and I have gone through the CD installing the drivers one by one and NOTHING else... No GFX, No Audio, No serial/parallel ports of anything, and so far, its runnign as well as can be expected. Next up is the GFX, but Im sure that requires DX9 and DOTNET 2 to go right...So, I will do those one by one too and see if it slows down afterwards... Long labourious process as I am doing a few tasks between each install of whatevers, to see if I can find an actual cause of the slowness?
