- 7 Mar 2011
Hi just got this and have built my first pc yay!
But in the Bios it shows that the cpu fan is going at 2000 rpms and the chasis fan 2 header (the H70 pump) is only going 1090 rpms. My cpu is around 40 degrees C at idle. I'm using a P8P67 Asus mobo and would like to know if this is a good standard or how i would throttle the H70 pump to get the idle temps lower cause i want to overclock sometime in the future. Ive tried using turbo settings in the bios and that doesnt seem to change the rpms at all.
I'm just worried the pump isnt gettin full power
Thanks
Thanks
