Help converting a .glb file to something I can use to 3D print?
2 Jun 2018
Hi
I have a .glb file (it's about 170mb) that I would like to convert to something I can load into a slicer and then 3d print.
I can load the file into 3D software, and it is a 3D representation of what it should be ...... I can't see any issues with the .glb file.
When I have tried to convert it to .stl or .obj etc it just doesn't work. I bae tried converting by exporting from my 3d software (blender) and also using online tools. they create an output files, such as a .stl but when I try to load this into a slicer (and I've tried a few) it just doesn't work. With Bambu slicer I get a message that there is no geometry data.
I am now at the end of my knowledge! And I would really like to print the 3D model ........ does anyone have any ideas? or would be able to help?
Thanks
Jonathan
If you can upload it somewhere and send a link (privately if necessary) I'd be happy to investigate.
