Help converting VB code to C#
18 Oct 2002
Edinburgh
Right, so i have a piece of code which converts an IEEE float (Number) in vb to a different representation of exponent and mantissa.
Im having great difficulty converting this to C# due to the way the code deals with bit masking of whole byte arrays. Anyone able to help?
Code:
      If (Number And &H80000000) = &H80000000 Then
         'negative
         'mask off the sign bit
         Number = (Number And &H7FFFFFFF)
         Mantissa = &HC000& - ((Number And &H7FFFFF) \ (2 ^ 9))
      Else
         Mantissa = &H4000& + ((Number And &H7FFFFF) \ (2 ^ 9))
      End If
      'positive
      If Number = 0 Then
         ' zero is represented as Mantissa 0 and Exponent 128
         Mantissa = 0: Exponent = &H80&
      Else
         Exponent = (((Number \ (2 ^ 23)) - 126&) And &HFF&)
      End If
Nope this is VB6 and their doesnt seem to be a direct conversion for this type of bit masking of whole integers and singles.
How about this...
Code:
        long number = 0x80000000;
        long mantissa;
        long exponent;
        if ((number & 0x80000000) == 0x80000000)
            //negative
            //mask off the sign bit
            number = (number & 0x7FFFFFFF);
            mantissa = 0xC000 - ((number & 0x7FFFFF) / (2 ^ 9));
        else
            mantissa = 0x4000 + ((number & 0x7FFFFF) / (2 ^ 9));
        //positive
        if (number == 0)
            // zero is represented as Mantissa 0 and Exponent 128
            mantissa = 0;
            exponent = 0x80;
        else
            exponent = (((number / (2 ^ 23)) - 126) & 0xFF);
That looks good except if i use a number say 555.55
the VB gives back mantissa 16385 and exponent 130
the code above gives back mantissa 16434 and exponent 156
ok so the whole point in the code is to convert a float to a mantissa and exponent
the code you did is good, but it only accepts a long (int) i need to do the same but to the float.
I think i have it, the numbers are not exact but i think thats due to the extra precission
Code:
        public void Marshall(float number)
            long mantissa;
            long exponent;
            if (((byte)number & 0x80000000) == 0x80000000)
                //negative
                number = ((byte)number & 0x7FFFFFFF);
                mantissa = 0xC000 - (((byte)number & 0x7FFFFF) / (2 ^ 8));
            else
                mantissa = 0x4000 + (((byte)number & 0x7FFFFF) / (2 ^ 8));
            //positive
            if (number == 0)
                mantissa = 0;
                exponent = 0x80;
            else
                exponent = ((((byte)number / (2 ^ 22)) - 126) & 0xFF);
            MessageBox.Show(mantissa + ":" + exponent);
Anyone fancy helping reverse it?? :O
I'd say there are a few issues here. First, you need to get the underlying representation of the float. Simply casting to a uint or long won't do the job. BitConverter will help there.
Second, the ^ operator in C# is not power, it's XOR. It's useful to know that dividing x by (2 ^ n) is equivalent to right-shifting an unsigned number n bits (i.e. x >> n). So you would end up with something like:
Code:
        public Tuple<uint, uint> Marshall(float number)
            uint exponent, mantissa;
            // First, convert from underlying representation
            var rep = BitConverter.ToUInt32(BitConverter.GetBytes(number), 0);
            if ((rep & 0x80000000) == 0x80000000)
                rep &= ~0x80000000;
                mantissa = 0xC000 - ((rep & 0x7FFFFF) >> 9);
            else
                mantissa = 0x4000 + ((rep & 0x7FFFFF) >> 9);
            if (rep == 0)
                mantissa = 0;
                exponent = 0x80;
            else
                exponent = (((rep >> 23) - 126) & 0xFF);
            return new Tuple<uint, uint>(exponent, mantissa);
To use:
Code:
var result = Test.Marshall(1.234f);
// exponent is result.Item1
// mantissa is result.Item2
It builds, but I don't know if it gives the "correct" answer. For the 555.55 case it returns (10, 17777).
Sorry for the late reply, you sir are a legend.
Thanks for that i forgot about ^ in C#
I finally nailed it, both ways thanks to your code:
Code:
        //Floating Point from a Mantissa and Exponent
        public Single MarshallReverse(int Mant, int Exp)
            long k;
            long m;
            long j;
            k = Mant;
            m = Exp;
            //Std representation of zero is mantissa 0 and exponent 128
            if (k == 0x0 && m == 0x80){ j = 0x0;}
            else if ((k & 0x8000) == 0x8000)
                //its negative so mask off the negative bit
                j = ((0x10000 - k) & 0x3fff) << 9;
                j = j | 0x80000000 | (((m + 126) & 0xff) << 23);
            else
                j = (k & 0x3fff) << 9;
                j = j | (((m + 126) & 0xff) << 23);
            byte[] ba = BitConverter.GetBytes(j);
            Single ans = BitConverter.ToSingle(ba, 0);
            return ans;
        //Procedure to create a mantissa and exponent from a float
            // If its negative
                rep &= ~0x80000000;
                //Subtract the sign and exponent and shift back 9 bits
            else
                //Subtract the exponent and shift back 9 bits
            if (rep == 0)
                //Std Representation of 0 is mantissa 0 exponent 128
                mantissa = 0;
                exponent = 0x80;
            else
                //Exponent is shifted 23 bits which clears them
            textBox9.Text = mantissa.ToString();
            textBox10.Text = exponent.ToString();
