- 10 Jan 2021
DOUBLE POST, I ALSO POSTED IN 'GENERAL HARDWARE' PLEASE DELETE ONE OF THE TWO.
Hello everyone I am new here
After I had a bad experience with ************ I decided to build my own computer in a Dan Case (yes, portable matters to me
I am completely new to PC building and planning, but after some researches, I understood that one of the most important things is a good cooling system and I need your help.
Here the plan:
Case: Dan Case A4-SFX v4
MB: Z490 PHANTOM GAMING-ITX/TB3 (SOCKET LGA 1200) DDR4 MINI-ITX MOTHERBOARD
CPU: I9 10900k
GPU: RTX 2080, (possibly ti)
RAM:
VIPER STEEL 64GB (2X32GB) DDR4 PC4-28800C18 3600MHZ DUAL CHANNEL KIT (PVS464G360C8K) (unless anything better / more suitable is recommended)
Power: Corsair SF600 600 Watt Fully Modular 80+
CPU Cooler: Here the question. I would like a Asetek 645LT AIO w/ Noctua A9x14 but it seems impossible to find it in UK. could you recommend me an equally suitable option (or even better)?
Budget is a problem up to a certain point for now, I am building a computer for work and I just want to make sure it can perform as I need. I also would downgrade some other components, but I want to forget about temperature problems
STORAGE: Probably a 2tb Samsung M2 (would you recommend me to have two separate ssd?)
FANS: I NEED YOUR HELP!!
Many thanks for now
Here the plan:
CPU: I9 10900k
RAM:
Many thanks for now
