- 18 Oct 2006
Hi there,
I have just finished building a PC from scratch and for some reason the cpu is around 52 c at Windows Xp. Soon as i'm trying to do something it goes up to 64-65 c. Is this normal or its to Hot???
My fan speed is 1780 it came with the cpu, i'm not sure if this fan should turn faster, and the cpu voltage is 1.14.
My MoBo is Asus P5WDG2-WS Pro, with a E6600 cpu and i'm using Corsair XMS2 Dominator Twin 2x 2048 6400C4D.
Does anyone have any idea what can i do to fix this problem or if there is something with any of my parts are not compatible???
Thanks
Thanks
