HELP CPU SPEED
19 Apr 2019
Hi Guys,
I hate to be this noobie...
i'm new to PC and i'm just curious to something when i go in my BIOS it says my CPU is at 4.33ghz untouched its a I700K CPU.
When i do a max load stress test my CPU goes to 4900 on NZXT CAM's and says 4955HGHZ on core temps.
I got the PC from OC has it been overclocked before been sent to me or am i missing something?
Many Thanks
Hi Guys,
Many Thanks
you most likely have multi core enhancement enbaled in bios ( motherboard automatically overclocks boost to 4.9)
ahh okay thanks will have a look when i do max stress test the cpu goes to 4900 and runs at about 80c is this bad? and does this mean if i was set it to 4900 i should be okay? of course i won't just put it straight to that i'm going to slowly increase it
the temps are okayish considering its not delided - however multicore enhancement pumps extra volts(not a major issues, unless you plan on keeping chip 5+ years) best to manually set voltage and OC
okay thank you. can you recommend the best place for overclocking as in voltages etc?
