Help-css
29 Apr 2007
London
hi im trying to make a navigation bar with image rollover but i don't know the code. The page is this and the rollover images are below it. Can you help?
if you could post the code here I would be eternally grateful.
here
I wouldnt bother rolling over with an image unless you want the whole thing to change. If you just want the text to change colour you need to add something like this (which i've just checked and it works).
Code:
.navbar li {
	margin: 0;
	padding: 0;
.navbar a {
	display: block;
	text-decoration: none;
	color: #ffffff;
.navbar a:hover {
	color: #0000ff;
This gives you a white text to blue text roll over
If you want the entire image to chage, you just give the background a url link.
Make sure then, in the html you make the nav linkable, like so
Code:
<div align="right" class="style2"><a href="#">Home</a></div>
  </div>
  <div class="navbutton1">
    <div align="center" class="style2"><a href="#">Contact</a></div>
  </div>
  <div class="style3">
    <div align="left"><a href="#">Other</a></div>
  </div>
Hope this helps a bit
