- 26 Mar 2010
as title says i need some tips whether the parts ive put together will run well.. or if i could swap out some for cheaper/better parts, thanks
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN
Cooler Master CM690-II Lite Dominator Case & GX 750W Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=BU-004-CM
MSI P67A-GD53 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
http://www.overclockers.co.uk/showproduct.php?prodid=MB-170-MS
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS
will be keeping my current GPU (xfx HD4890 1gb)
and keeping hard drives (samsung f3 1tb)
might possibly be purchasing win7 home premium 64 bit as well
my budget is in the region of £600 and hopefully it will last 2+ years and will be used for just gaming, no super overclocks or running at ultra, just average
