Help deciding on PSU!
15 Jan 2010
Scotland
Looking to upgrade my current PSU to one that is a bit more efficient. Don't really want to spend over £100, so I've scouted out two contenders
Antec EA 550w
http://www.overclockers.co.uk/showproduct.php?prodid=CA-191-AN
Seasonic G 550w
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-SS
Both the same price, but I'm leaning towards to Seasonic just because of what I've heard about the brand and the modular cables. Anyone had any experiences with either? Is it worth sacrificing the Platinum efficiency for the Seasonic?
And also, I run 550w right now and that is capable of running my overclocked 670 and 2500k, but do you think either of these PSUs could take 670s in SLI if I managed to pick one up super cheap sometime?
Thought that might be the case, I've never done SLI and to be honest I'd probably just put the money towards a newer model when the time comes, getting a 750w 'just in case' and running one 670 would be a bit overkill.
