Help deciding which motherboard
11 Apr 2004
Isle of Man
I'm deciding on my new build at the moment, my 10 year Athlon Xperia 2.5GHz is going to be retired!
I've decided on the case, psu, cooling and cpu... Probably the i5 4690k.
What I've struggled to find is a mATX mobo with 10 x Sata ports.
Can anyone suggest any? I've looked at the AsRock Z87M OC Formula, which on overclockers says 10x sata, but when I look up the spec, it only has 6.
Be great to find a couple to compare!
Thanks!
