Hi all,
I was wondering if I could get a help troubleshooting a pc problem. In the last few days my pc has been cutting out randomly, then restarting, going straight to the bios, crashing again, before starting normally. I took all the components out bar 1 stick of ram and cpu and still crashing. I turned off automatic restarts to see if there was a blue screen, but there aren't any. I installed the gigabyte monitoring software to look at voltages and annoyingly it doesn't keep a record of when it crashes. So I only have data from when it doesn't crash. Not very helpful chart:
I suspect it is the psu giving up? It is 7 years old now, so I should get a new one? I have no other components to test with.
Thanks for your help
AMD FX8320 Black Edition 8 Core (3.5/4.0GHz, 8MB Level 3 Cache, 8MB Level 2 Cache, Socket AM3+
Gigabyte 970A-DS3P AMD 970 Motherboard (Socket AM3+, DDR3, S-ATA 600, ATX, PCI Express 2.0 x16, USB 3.0)
SAPPHIRE AMD R9 280 Graphics Card (3GB, DDR5)
Samsung 840 EVO 120GB 2.5 inch Basic SATA Solid State Drive
Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
OCZ Stealth Xstream II 600W PSU - 3x SATA 2x PCI-E
Western Digital WD5000AAKS 500GB SATAII 7200RPM 16MB Cache
