13 Aug 2009 at 21:12 #1 Th3D0n Th3D0n Associate Joined 3 Jul 2007 Posts 1,958 Location Rochdale/whitworth Dose anyone know how to disable IMAPI CD-Burning COM in windows 7
13 Aug 2009 at 21:33 #2 ns400r ns400r Soldato Joined 23 Apr 2004 Posts 3,580 Location UK, Near the middle...... Done via a registry change that I can't remember.
13 Aug 2009 at 21:36 #3 Th3D0n Th3D0n Associate OP Joined 3 Jul 2007 Posts 1,958 Location Rochdale/whitworth ns400r said: Done via a registry change that I can't remember. Click to expand... cant find it in there!
13 Aug 2009 at 21:37 #4 ns400r ns400r Soldato Joined 23 Apr 2004 Posts 3,580 Location UK, Near the middle...... Maybe this one - http://www.sevenforums.com/tutorials/5942-burning-cd-dvd-enable-disable.html Doesn't disable the ability to burn .iso's though.
14 Aug 2009 at 12:42 #5 Richard_ Richard_ Associate Joined 5 May 2008 Posts 131 Stopping the serivce will only stop windows not other apps like nero working well that is how it works on windows XP so check after you have done it
