Help! Does the PWM,s control the Cpu Core voltage?
2 Jan 2009
Hi I think my motherboard has packed in on me as the display fault code shows the cpu core voltage fault. I have recentley replaced my heatsink on my PWM with water cooling block, Could this be the fault and what motherboard would you reccomend as i am running SLi and dont want to upgrade to i7 yet as cant really afford it. Thanks in advance.
Yip the PWM's play a major role in controlling the power running through the CPU socket.
Which motherboard? Have you tried putting the original heatsink back on them?
Yes and still no luck must have gave up on me. I am looking at the EVGA 780i and the Asus striker 2 formula. Can you reccomend the better motherboard?
