*help* Download failed on W800i MMS...?
19 Dec 2003
UK
Hi folks,
I got 3 MMS messages, all from the same person.
The first one worked, the second one has a picture of a broken envelope, the 3rd arrived, and the same.
It says 'Download failed' when I try to open them.
I have re-downloaded MMS settings (Though I cant see why if the first one worked)
Any ideas if I can get these 2 to re-download?
Thanks,
Sean
Try redownloading the message (try opening it in the inbox) and it should say downloading. If it still doesn't work ring customer services as it may be a problem with the network.
Matt
