help drivers window side fell out
11 Oct 2005
Derbyshire
Hi my renault laguna (W) reg has decided to have another problem, one thing afte the other, the drivers side window when it goes down and up has pretty much come out? not going up and down correctly it is all over the place.
either comes into the car or bends outwards.
Any one know what it could be and if possible to sort it yourself ?
Always one thing after the ruddy other with this car.
Are they on runners that may have come off or what ?
wont slide up, its like it has come off of whatever pushes it up and pulls it down.
Thanks
have to work out HOW to take panel off, looks like invisble screws holding it on. Cannot see them. Could it just be a case of it has popped of the runners?
It should sit in a pair of runners and if it is anything like my 19 there will be a nubbin which goes through a hole in the base of the glass with a clip on the other side. You should be able to sort it yourself. I suspect its held on by a combination of poppers round the edge of the panel with Torx bolts holding things like handles on. Got a pic of the door panel?
just took panel off and there is a kind of sheet thats held on over the whole door with a wet glue type susbtance, got it all over me, not touched it since as dont know what to do about the glue
Cut the glue carefully with a knife/blade until it comes off.
