- 22 Feb 2014
I caused a leak in an ensuite bathroom a few days ago that had mains pressure hot water spraying into the room for 30 - 60 seconds roughly.
I turned off the water and then mopped the floor and left a fan running overnight.
next morning the ceiling in the room below had some staining on it over a fairly large area maybe 1.5 -2 m2
the issue I have is that the room below after a few days smells of damp plaster still.
I have had fans blowing in both the bathroom and pointed at the celling in the room below.
I have a portable aircon with dehumidifier function that I can try, would this be better in the room below or the bathroom itself ?
anything else I can do short of ripping up the bathroom floor (its kardean over 3mm ply, which would also need removal of a toilet so not keen on this idea)
