Hi guys, I need your help.
I turned in tv on my computer and fell asleep for an hour or so and when i wake up there is sound but no dvi signal to the screen. I have been running my new 2900xt faultlessly for a weeks time and now suddenly I cannot seem to be able to get a signal out of the card???
What should I try before i decide for RMA-time?
When I start the computer the card fan gets running, so it is not totally bust.
The red light on the card turns on very briefly at powerup, but I think to recall it doing so when I first installed it.
Hard to do any diagnostics without a screen-signal. any suggestions?
My spec is as follows:
Athlon 64 X2 4400+
Antec SLK3000B (case)
Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU
OCZ 2GB PC3200 Dual Channel Platinum Series
NEC MultiSync® LCD20WGX2
Windows XP x64
Asus A8R32-MVP Deluxe
X-Fi Fatal1ty
A Leadtek tv-card (DTV2000 I think)
And two WD 500GB disks and a 200GB (i tried running only one to check if it was a powerproblem)
Thanks
Athlon 64 X2 4400+
Windows XP x64
X-Fi Fatal1ty
Thanks
