Hi guys
Haven't been on here a while as my PC hasn't needed anything doing.
I have, however, just built a friend a PC spec'd as below:
-E8400 (stock speed)
-Arctic Freezer
-Abit IP35P MOBO
-4 gig Crucial ram
-ATI Radeo Hd4670
-Several HDs and DVDRW!
-Coolermaster case + 120mm fans + 480w PSU
Anyway, built the pc without issues (I have built loads).
On boot up, checking the bios it showed the CPU as 98oC (10 seconds in)
I shut down the machine and checked that the cooler was seated properly and it appears to be - TIM etc melted and cooler is firmly seated.
Any ideas? Tried a bios flash and the PC is running ok but haven't 'stress tested it'
Hasn't moved from 98oc despite running it a while?
Cheers!!
-Arctic Freezer
-Abit IP35P MOBO
-4 gig Crucial ram
-ATI Radeo Hd4670
Cheers!!
